It is currently Sun Jul 20, 2025 11:15 pm
 Post subject: Carve top thickness?
PostPosted: Tue Feb 28, 2012 3:55 pm
First name: Ringo
I have some pretty wood that I think would make a great Les Paul-style top, but it's not 5/8" thick. What's the minimum thickness for a carved top? 1/2"?
 Post subject: Re: Carve top thickness?
PostPosted: Tue Feb 28, 2012 5:10 pm
Depends on how deep your top carve is. I've toyed with the idea of doing a 3/16" deep top carve on a 1/4" piece of wood. Haven't done it yet. I think it might be pushing my luck, but I bet it would work if I was careful.
However, for a Les Paul, I think 1/2" would work just fine.
PostPosted: Tue Feb 28, 2012 5:31 pm
Are they 5/8th's thick?
Doesn't matter. It can be as thin as 1/4th inch (or thinner depending on your carve profile), make up the extra thickness with the body. Carve the top down to 1/32 at the edges and bind it. No one will ever know or care.
I usually do mine 1/2 inch thick.
Old growth, shmold growth!
PostPosted: Thu Mar 01, 2012 10:31 pm
First name: shad
Last Name: peters
The first time I ever tried carving a top I tried to do it with a 1/4" thick piece of figured cherry. My advice: dont do that. Pretty much ruined a nice piece of cherry, if you are starting with anything much less than a 1/2 I wouldnt carve it, to me it just kinda looks odd. also the thinner your carve is the harder it will be to get it nice and even, a thicker carve is just a little bit more forgiving. If it is thinner than 3/8 i say you are better off making a flat top.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
